September 04, 2015, 06:07:24 PM
Author Topic: My Zune has a black screen. PLEASE HELP!!  (Read 16187 times)
0 Members and 2 Guests are viewing this topic.
TheAce75
« on: September 23, 2008, 08:44:25 AM »
Someone please help me. i was listening to my white 30 gb zune and all of a sudden it froze(as usual) so i decided to reset it. Once i reset it, the usual zune logo appears when it starts up but then after that the screen is just black.  The zune IS on cuz u can see the backlight but the screen is completely black and u cant play any music.  I've reset like 20 times but it doesnt do anything and even when i connect it to the computer, the zune program doesnt recognize it and it doesnt do anything. Has this happened to anyone else? If so, how do u fix it?
BCON
« Reply #1 on: September 23, 2008, 08:53:41 AM »
let the battery drain .. then recharge it
DONT FEED THE FRNCHDP
Nirvana 05
Uber Nerd
« Reply #2 on: September 23, 2008, 11:59:59 AM »
another solution might be if you completely erase all contents, incluiding the software...
You got to press some button combination while resettig it.
Afterwards try to  reconnect it to your PC.
In case of emergency: Stop screaming.
BCON
« Reply #3 on: September 23, 2008, 12:08:59 PM »
thats deleting the "frimware"
try the battery drain first ... then if that does not work reset the firmware ..
TheDaarkness
Uber Nerd
« Reply #4 on: September 23, 2008, 03:23:46 PM »
hold down the back and up button. someone else here posted that solution
BCON
« Reply #5 on: September 23, 2008, 03:37:58 PM »
i think the OP already tried that he refers to it as "reset" the up and back is a "soft" reset
TheAce75
« Reply #6 on: September 23, 2008, 04:29:55 PM »
I tried the letting the battery drain thing but it didnt work!!! How do u do the reset to erase all contents/firmware? Ive already tried the regular reset.
Nirvana 05
Uber Nerd
« Reply #7 on: September 24, 2008, 12:27:07 PM »
http://support.microsoft.com/kb/927001/en-us
There you go.
Good luck, you'll need it.
If it doesn't work contact customer support.
yemajose
« Reply #8 on: May 24, 2011, 11:17:56 AM »
Hi everyone, I need your help.I am having exactly the same problem with my 30Gb non touch screen zune.Please help...
Unicron Social
« Reply #9 on: May 24, 2011, 11:31:02 AM »
do what the post above yours says, then post the results and we will go from there.
Page created in 0.109 seconds with 22 queries.
